Tracking down an elusive electrical issue
It took a while....
I've had a problem for the last couple of months with an intermittent power loss in the ignition circuit.
The bike would run fine and then I'd stop somewhere and when I came out to leave, the bike would crank over but not start.
A couple of times I trailered it to the house and when I got it off the trailer, it would start right up and run fine.
I had an Ignition module in my shop, so I swapped it out.
I swapped out the bank angle sensor with one that I borrowed from a friend.
I swapped out the coil with a new one that I had.
No luck!
Last weekend I left the house on the bike and about a mile from home it just died, like I shut the key of....Same thing, crank/no start.
When I got it home, it wouldn't start either, so I started tracking it down...1/2 hour later, I found the problem.
It was the kill switch!
I swapped it out with a new one and took the old one apart and found it was a wire broken on the inside of the switch....Never seen one do that before.
Oh well....It's fixed now! I'm goin' for a ride!
No luck!
spike95
11-29-2008 02:28 PM
