Real world difference in stopping? Single vs dual
Old 03-31-2016 | 07:25 AM
shekmark's Avatar
shekmark
Default Real world difference in stopping? Single vs dual
I have a 2015 Street Bob with ABS. Wondering if the dual set-up with ABS is a whole lot better than my single with ABS. Any real testing stats out there? Stopping matters a lot to me. If there was a real big difference I would consider trading to a Lowrider with ABS.
Old 03-31-2016 | 08:47 AM
enodrano's Avatar
enodrano
Your Street Bob is light enough that a single setup is more than adequate. I wouldn't wory about it.
Old 03-31-2016 | 09:12 AM
multihdrdr's Avatar
multihdrdr
Stats are informative, but you can judge for yourself (seat 'o pants)...ride a Low Rider or maybe a Fat Bob
Old 03-31-2016 | 09:34 AM
Rockabillphil's Avatar
Rockabillphil
Something to consider and somehow affordable is to change your disc and pads for Lyndall or EBC products, for example.
And if you still have money, change the caliper also. PM makes some good calipers for our bikes but you can also go the speed merchant route with their bracket that will allow you to fit a +06 GSXR600 caliper.
I think dual disc will dissipate more heat (ie: racing on a track or intense and long canyon riding session...).
On a relatively light bike like the street bob, I think a single disc brake system, with the good parts, will do the job for most of us.
Old 03-31-2016 | 10:03 AM
NMfxdf's Avatar
NMfxdf
I have never seen any actual stats, I do know that my FXDF is the first motorcycle I have ever had with duals and it can really brake. I practice, as I am sure most do, threshold braking a lot, and that dual setup can almost stop harder than my rear can suck to the seat.
Old 03-31-2016 | 12:03 PM
itscaptaincody's Avatar
itscaptaincody
You are doubling the brake power... I personally have an 07 FXDL and find the single front brake to be lacking and will be converting to duals (as I find parts cause I'm cheap). There is a multitude of ways this can be completed; speed merchant brackets, FXDL or FXDF caliper, Touring Brembo calipers, V-Rod parts..
http://thespeedmerchant.net/product/...ack-dual-disc/
Allows you to run 05 + GXSR brakes - nothing but stellar reviews across the net.
You will need an 08+ FXDF or 14 + FXDL RT fork slider. Depending on your rim you may need to change that as well.
This thread will give you a lot of useful info with part numbers for using HD parts only.
https://www.hdforums.com/forum/dyna-...t-numbers.html
Old 03-31-2016 | 12:08 PM
big ron's Avatar
big ron
Have been looking to convert or put a single side brembo off a sport bike.
Old 03-31-2016 | 12:13 PM
multihdrdr's Avatar
multihdrdr
If you aren't aware of it.
https://www.hdforums.com/forum/dyna-glide-models/1091508-real-brembo-front-caliper-installed.html
Old 03-31-2016 | 12:23 PM
shekmark's Avatar
shekmark
Can you change the brakes on an ABS model? I would have no problem upgrading to a bigger caliper if it's ok to do with ABS
Old 03-31-2016 | 12:42 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I rode an SG for 21+ years with a solo rotor. When the bike had it's stock cam , it was sufficient. When I changed cams, the higher lift and mostly the longer duration caused a huge reduction in "engine compression braking." Suddenly, the single rotor up front was inadequate. I still rode it but rarely 2-up and in steep hills.
One thing I noticed right away was how much more engine braking effect I have on my 2016 FXDL. That, and I don't have to squeeeeze nearly as hard on the lever as before. This may be construed as "better brakes" but I'd say they're just different brakes as the old single rotor worked ok. You just had to SQUEEEEZE like hand exercises!
Quick Reply: Real world difference in stopping? Single vs dual
