FXR rear brake
FXR rear brake
After owning my 91 FXRS for almost a year I'm finally ready to rebuilt the bike. I need some advise concerning what I should use for the rear brake. I want to go with a 4 piston caliber. The guy I'm working with who's going to redo the engine and transmission is telling me that Performance Machine's 4 piston brake does not do a good job, he told me that with the rear brake engaged he can easily move the bike forward. Anyway I'm looking for any advise concerning this. The biggest issue seems to be the brake bracket, or lack there of...
Looks Good "O"...is that chin spoiler Aluminum? I think I have an unpainted version of that
The rebuild will be a frame up restoration including upgrading the bike to run Harley's dual 4 piston caliper fronts, rebuilding the motor with a 89 stroker, screaming eagle heads, mikumi 42mm carb, electronic speedo and tach, etc. The bike will be equipped with Harley floating rotors front and rear so basically the bike will NOT be stock when I'm done. I'm using as much Harley stuff as I can. If you think that it's still good to run the stock rear brake, then so be it... That's why I'm asking for advice here...
Hundskrüppel
02-06-2018 01:41 PM
