Custom gauge cluster
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
I'm using some scrap steel I had that is 0.065 thick. I think it will work just fine.
It seems to be a good thickness to fit between the risers and the clamp.
I had to grind off these rings from the clamp.
Each gauge will be angled back about the same as the stock speedometer bracket.
Received 5,424 Likes
Here is the setup on my 1991 Sportster. I just used the stock bracket flipped 180 and upside down. PITA with the older bike due to the idiot lights, but gauges were easy. Without the lights I could see you OIL gauge stuck in the middle. Fresh wrinkle paint.
PS note that HD put it on top of the clamp, has longer bolts and a spacer below the bezel. Just a thought, having it between the clamp and risers might compromise the clamping ability.
