Jiffy Stand Bumper Install
Old 03-23-2016 | 11:31 AM
hd4evr2008's Avatar
hd4evr2008
Default Jiffy Stand Bumper Install
Lost the rubber frame bumper off my new Low Rider already! New one coming tomorrow. Any "trick" to installing this thing? I know it's kinda spring loaded, but does it just snap on the frame rail?
Old 03-23-2016 | 11:42 AM
TinCupChalice's Avatar
TinCupChalice
It's going to look like this:
It goes on the frame tube as far back as you can push it, up against the weld at the rear. The longer portion is positioned upward, you sort of snap it in place around the frame tube. It helps if it's warm, that little bugger is stiff. From there sit on the bike and raise the jiffy and test how the jiffy hits the face of the bumper, the face of the bumper will be rotated downward to catch the jiffy solidly. Reach down with the jiffy up and you'll feel how the jiffy is contacting the face of the bumper, rotate the bumper so it contacts solidly.
Done, enjoy beverage!
hd4evr2008 (03-23-2016)
Old 03-23-2016 | 03:14 PM
hd4evr2008's Avatar
hd4evr2008
Sounds easy enough, thanks!!
Old 03-23-2016 | 03:54 PM
butterballs's Avatar
butterballs
Mines gone too. Anybody know the part # for it.
Thanks
Old 03-23-2016 | 04:48 PM
hd4evr2008's Avatar
hd4evr2008
Originally Posted by butterballs
mines gone too. Anybody know the part # for it.
Thanks
h-d #50054-01
butterballs (03-23-2016)
Old 06-27-2016 | 09:30 AM
BigDogIdaho's Avatar
BigDogIdaho
I've lost my third one. Does anyone make one that is more "permanent"?
Old 06-27-2016 | 09:48 AM
TinCupChalice
I don't recall seeing one off-hand. Are you knocking it loose in some way? If you use a lift you can easily knock them off or loose. The only lift that will clear everything on the Dyna is a J&S. Is the jiffy bumper angled so the jiffy solidly hits it when the jiffy comes up? Having the bumper mis-aligned with the jiffy smacking in to it could knock it loose, too; then a bit of road vibration and it falls off...
Old 06-27-2016 | 12:33 PM
BigDogIdaho
The first one I lost I know I scraped it and that is what caused it. The other....??
I may have knocked it loose a bit last time I had it up on a lift but that's been awhile. Of course it could have worked it's way off through time after the jack knocked it loose.
Oh well...at least they are cheap
Sapman
07-09-2019 01:36 PM
Scott Wagner
05-10-2018 08:41 AM
hd4evr2008
03-18-2016 01:32 PM
CACruiserHD
08-18-2014 04:23 PM
Rain
09-28-2007 09:10 PM
Quick Reply: Jiffy Stand Bumper Install
