Will this wheel be ok for a 200 tire '14 SB
I posted a few days ago about fitting a 200mm tire on my '14 Street Bob and have read through loads of threads.
Can anyone tell me if this wheel will be OK to use? I expect I will have to use a spacer or will I have to have my existing hub fitted to it?
http://www.harleycustom.co.uk/UK_Per...576_2639_26823
That hub is considerably different than yours. You would need new brake rotor, pulley, bearings, & bearing spacer at a minimum. It would be easier to lace a new rim to your hub. Buchanan's and HDwheels both sell rims, but I've not seen that particular rim. I would assume PM offers that wheel with the correct hub, tho.
