Vee Twin Racing street ported heads
I talked to Kirby at Vee Twin Racing about doing some heads for me. We talk for an hour and because I cruse 95% of the time he said he would go with the street ported heads. I boxed them up and sent them to him. Got them on and put a throttle body I had bored by Max Bore that is now 50mm. so here is what I got.
2007 Dyne SB
Supertrapp 2-1 exhaust
SE air filter backing plate with Zippers max flow filter
103 kit standard compression
Andrews 57H cams
50mm throttle body with high flow injectors
Vee Twin Racing heads with 1.90 int and 1.61 ext valves
10.25 compression
Power Commander PCIII usb
Dyno guy did a base tune and then went to work. He started doing runs from 1200 rpm. Engine pulled from there. Made 90 TQ ar 2000 rpm. Kirby dose some good head work.
On the dyno for 3 1/2 hours
103 HP and 112TQ
This bike fly's!!!
2007 Dyne SB
Andrews 57H cams
10.25 compression
103 HP and 112TQ
This bike fly's!!!
im sure it is,im sure its doing 110+ on the tq side & im sure its doing more in the hp area too (even with VERY mild 95" motors,our heads have done way more than 100 #` tq) run it on a 250 DYNOJET dyno
I have tried from 6 disk to 22 disk and 15 seems to work best for me. My brothers RK has a Fuel Moto 107 kit and heads. Has 55mm throttle body. Has Woods 777 cams and supermag. Open endcap like I hace and 18 disk. RK primary tubes are longer the on my exhaust. He did 115HP and 115TQ but has a lot more money in it than I do. He is on his second set of heads. He did not like the first set because of a power dip around 3000 rpm.
