My STUPID little hands can't reach the levers!
Old 03-10-2016, 09:26 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,314 Likes on 1,861 Posts
These help your "Hands" GROW
Old 03-10-2016, 09:36 AM
tcarson84's Avatar
tcarson84
tcarson84 is offline
As i don't have this problem but was reading post anyways, I got to thinking that if this doesn't work you could try the rekluse clutch so you wouldn't have to use the clutch lever as much especially in town. I know its much more expensive than levers but maybe when it comes time to replace the clutch you could switch over.
Old 03-11-2016, 10:07 PM
damager1's Avatar
damager1
damager1 is offline
Originally Posted by nevil
I have the Oberon clutch lever which I needed due to an injury. It's a beautifully well made unit and has a lot of reach adjustment. I compared them to the Roland Sands levers but decided that 1/4" or less adjustment wasn't worth it. The Oberon uses a cam system as a pivot point and I could tell right away that it also reduced the effort to pull in the lever.
I'll be getting the brake side lever this spring.
Here's a pic where I clamped the old lever on top of the Oberon so you can see the difference.
WOW!!! holy smoke i think that just made my decision. I think i'll spend a few bucks more and just get the Oberons. Thanks for that pic, VERY helpful! man, it's like a good 1/2 to 3/4 inch difference!
Old 03-11-2016, 10:16 PM
damager1's Avatar
damager1
damager1 is offline
holy **** these rule too! haha i'm so glad there's exceptionally smart and exceptionally horny people out there OTHER than me. (the horny part, i mean)
Old 03-25-2016, 09:47 PM
Ben Fauzio's Avatar
Ben Fauzio
Ben Fauzio is offline
Maybe not what you want to hear but I threw some dirt bike grips on. Also put some big al shorty levers. Most likely not the look your going for but it might be.
Old 03-26-2016, 10:42 AM
dlporter's Avatar
dlporter
dlporter is offline
Another plug for RSD adjustable levers here. I also wear size medium glove so I feel your pain. As mentioned peviously, the clutch cable still has to travel a certain distance to fully engage. If you adjust the lever in close enough you may have to adjust your clutch a little to make sure it fully engages and isn't dragging.
2ndTink
2018+ Softail Models
04-17-2019 08:01 AM
harleychik1
04-07-2013 09:18 AM
Mountain Bound
11-03-2011 07:45 PM
Daisy
04-20-2010 07:30 AM
Beefcake
05-17-2005 02:06 PM
Quick Reply: My STUPID little hands can't reach the levers!
