clutch adjustment?
RE: clutch adjustment?
Well I went back and readjusted mine tonight - here's what I did...
Loosen the jam nut on the clutch cable under the boot, loosen the big nut til there's a lot of slack and pull the lever a few times.
I loosened the lock nut on the pressure plate and backed off on the adjuster and then ran it all the way in hand tight with the extension and hex bit (no ratchet). The book says to lightly seat it - well that's nice and all but I took that has lightly and it was too loose so all the way in by hand without any extra effort and backed it out about 3/4 turn and tighten the lock nut.
Then adjust the cable by tightening the big nut til there's about an 1/8" free play. Tighten the jam nut.
Mine feels pretty good now
Comfortably Numb
05-03-2021 01:45 AM
