RIDEMYBIKEMIKE'S 2008 Bob to Bagger build FLDYNA
Old 02-29-2016 | 12:26 PM
ridemybikeMike's Avatar
ridemybikeMike
If you don't care that they are black you can get any 14+ Touring lower legs doesn't have to be SG. I opted for these as I wanted black instead of brushed alum or chrome. Iv seen the regular brushed alum ones with cowbells for as little as 100 for the set
  #52
Old 03-08-2016 | 05:11 AM
Bobby12012's Avatar
Bobby12012
Any progress on that fairing?
I'm really curious to see how it turns out :
  #53
Old 03-18-2016 | 04:29 PM
Bobby12012's Avatar
Bobby12012
Another question ... Aren't the street glide lower legs a little shorter than the Dyna ones? Maybe 1/2 to 3/4 inch shorter ? Did that cause any issues?
  #54
Old 03-19-2016 | 02:49 PM
ridemybikeMike
Originally Posted by blueangel73
Did you purchase the lowers and wing new or used? If used, online or local?
Got almost everything nearly new take offs from local craigslist ads except for the fat bob triple trees , got those new from Newcastle harley for 220, $60 cheaper than anywhere else I could find.
  #55
Old 03-19-2016 | 02:51 PM
ridemybikeMike
So far iv got the inner fiberglassed, about to make speaker domes and then bond and sand. Ended up ditching the HD quick release windshield clamps cuz it made the fairing stick too far forward. Found some cheap black turn signal relocation clamps got 3 set, 2 for fairing and 1 for lower fairing panel that covers fork. Pics to come
  #56
Old 03-19-2016 | 02:53 PM
ridemybikeMike
Yes I was concerned too but no noticeable difference as far as I can tell. Between that and the air shock the bike actually sits taller. Ended up lowering the triples (raising forks) to close the gap between cowbells and fairing lower panel
  #57
Old 03-19-2016 | 03:03 PM
ridemybikeMike
  #58
Old 03-19-2016 | 03:09 PM
ridemybikeMike
Next step is to finish the inner with some speakers and amp in the bag. Sending the last few ugly chrome bits off to powder coating monday.
On a positive note I got the rear brake linkage issue worked out so I can ditch the add on plate and have effective braking ability
Had to griND the lever quite a bit to clear my v+H 2-1 exhuast.
Getting all levers brake and clutch arms bag latches top triple clamp primary cover horn cover and any other ugly chrome bits done black thus coming week
  #59
Old 03-19-2016 | 05:45 PM
Bobby12012's Avatar
Bobby12012
What size is your front wheel ? 17 or 18 ?
Your Dyna caliper and the stock road glide rotor?
I assume that all the different size front wheels have rotors that match up to the caliper since the fork legs are all the same regardless of the wheel size?
ridemybikeMike (03-19-2016)
  #60
Old 03-19-2016 | 05:55 PM
fxdlx's Avatar
fxdlx
You gonna trust the brake lever don't snap when you need it? No porosity in that weld?
Quick Reply: RIDEMYBIKEMIKE'S 2008 Bob to Bagger build FLDYNA
