RIDEMYBIKEMIKE'S 2008 Bob to Bagger build FLDYNA
Old 02-28-2016 | 06:11 PM
ridemybikeMike's Avatar
ridemybikeMike
Cowbells are held In place using a simple strap clamp and 2 L brackets wedged between it aND the fork tube. Then I ran 2 bolts thru a hole in the L bracket directly into the 2 holes on the cowbells that normally bolt to the lower triple on FL models
  #42
Old 02-28-2016 | 07:22 PM
blueangel73's Avatar
blueangel73
Originally Posted by ridemybikeMike
They are just stock 14/15 flhx LOWERED legs, the 49mm tubes are what came on my 08 dyna. Cowbells are also stock 14/15 flhx tins.
I plan to mount the fairing using the HD quick release windshield brackets tied into the custom inner. Iv cutout some foam I plan to try my luck with fiberglass. Gotta figure out what size and how many speakers I will run b4 I can go much further.
So you pulled your stock lower legs off the full legs and replaced with the newer FLHX lowers, any issues doing the swap or is it just like a typical rebuild of the forks?
Also, I was wondering if putting a lowering kit in the legs would close up the gap.
  #43
Old 02-28-2016 | 08:23 PM
ridemybikeMike
That's correct. Same as a rebuild just used the flhx lowers. Needed 1 pinch bolt and of coarse the touring axle
And yes a lowering kit or moving the forks up in the triple wI'll effectively close that gap, I'm waitong to see what happens with the lower fairing panel first to see if it covers it, if not il do one of those two options. I'd prefer to not lower the bike if possible as I already drag exhuast on hard right handers
  #44
Old 02-29-2016 | 12:01 PM
ridemybikeMike
Quick sneek peek of finished product. Waiting on my fairing brackets to get back from powder coat, gotta start the inner fairing work b4 much else can get finished
  #45
Old 02-29-2016 | 12:03 PM
ridemybikeMike
Decided to ditch the cheapo HD tea straw air shock setup in exchange for a much more solid sturdy line and fittings. Still tryin to get it all ironed out
  #46
Old 02-29-2016 | 12:05 PM
ridemybikeMike
Anyone know where I can buy black 1/2" hose clamps by chance?
  #47
Old 02-29-2016 | 12:14 PM
blueangel73
Can you drop the fairing down any, seems a little high up IMO.
  #48
Old 02-29-2016 | 12:17 PM
ridemybikeMike
Yes it will sit lower in the pic it is just balaced sitting on the quick release clamps, not the final positioning. Just a quick look at what it will be once completed
  #49
Old 02-29-2016 | 12:19 PM
blueangel73
Did you purchase the lowers and wing new or used? If used, online or local?
  #50
Old 02-29-2016 | 12:23 PM
ridemybikeMike
The lower fork legs and cowbells were purchased from my buddy who owns a 14 SG for 200 (same as what u can score em for on evay)
The outer fairing and front 2014 SG fairing and front fender were found on Craigslist. I paid 200 for both which was a smokin deal as far as I'm concerned
Quick Reply: RIDEMYBIKEMIKE'S 2008 Bob to Bagger build FLDYNA
