So those are completely stock legs off a 2014 Street Glide, top to bottom, did I catch that correctly?
Can you provide details on the cowbell installs? Also on how you are mounting the batwing?
They are just stock 14/15 flhx LOWERED legs, the 49mm tubes are what came on my 08 dyna. Cowbells are also stock 14/15 flhx tins.
I plan to mount the fairing using the HD quick release windshield brackets tied into the custom inner. Iv cutout some foam I plan to try my luck with fiberglass. Gotta figure out what size and how many speakers I will run b4 I can go much further.
You can buy longer cowbells, up to 2 inches I believe. You may have to widen from 41mm if they are not yet available in 49mm.
That's the plan if the lower filler Panel that the 14/15 fairing has doesn't cover the open space. I'd still have to use a similar setup to attach as the fxdf triple trees don't have any bungs to attach like the FL triples do. Hoping I won't need to but good to know they are out there
