My search for what's causing my idle issues...
Old 03-04-2016 | 09:57 AM
hitman1267's Avatar
hitman1267
Originally Posted by WMX124
Did you already re-flash your tune?
Not yet soon. I gotta find a windows computer lol!
Old 03-04-2016 | 09:58 AM
hitman1267's Avatar
hitman1267
Originally Posted by JohnMn
Have you tried running a good dose of injector cleaner in the tank?
And/or running a higher octane fuel? Cloud be the place you get gas just has some nasty fuel your bike don't like.
I'll go ahead and pick some up! Thanks bro!
Old 03-04-2016 | 10:00 AM
hitman1267's Avatar
hitman1267
Originally Posted by HrdNox
Have you looked inside you tank with a good flashlight? A lot of turbulence usually indicates a hole in you line. Sounds like it may be sucking air.
I did once when I suspected a leaky fuel hose and all I saw was the fuel return spraying fuel back in the tank.
Old 03-11-2016 | 06:07 PM
hitman1267's Avatar
hitman1267
I reflashed the tune and i see that the throttle position goes from 0 to 4 rapidly
Old 06-13-2016 | 02:09 PM
hitman1267's Avatar
hitman1267
I figured it out. Was just browsing around on different forums I found on google and I forgot to check the engine temperature sensor. It is screwed into the front cylinder. The sensor came out with little effort. I guess it was loose. Well I continued to pull it out and then i cleaned the sensor and re-tightened it. After that I've only had a minor hiccup. In the future I will change that sensor. MPG's went back to normal and throttle response was back to normal. The erratic idle problem went away after messing around with the engine temperature sensor.
Funny thing is that the sensor doesn't show a code if it malfunctioning. It will act like its leak in the intake system or exhaust. I hope this thread will help anyone else with this issue.
FattyMcJ (06-14-2016)
FXDBij
05-29-2019 12:56 AM
rebel7
08-07-2017 09:36 AM
hitman1267
08-04-2016 01:34 PM
HDnoob
09-26-2011 10:03 AM
CCPD
01-10-2008 06:54 AM
Quick Reply: My search for what's causing my idle issues...
