Question to Power Vision users/owners
So it's sort of looking like the Power Vision would be the best/easiest choice for when I jump up to stage 1. But I have a few questions;
So right now I have stock A/C, stock computer, and V&H short shots. I am planning on getting the power vision, DK Customs A/C, and Thrashin' SS Exhaust. Does anyone else have this combo and like it? Using auto tune could I just install all of those and ride it and end up with a good tune? Would like some details on how easy it is to tune and how good can you really get the tune. Also want to make sure that doing that and running it with the stock tune while its doing the auto tune won't damage my motor at all. Thanks!
Yes - buy it from Fuel Moto and tell them what your configuration is. They will pre-load it with a custom map for your setup.
Autotune is easy and gives good results. If you have the stock 12mm narrowband O2 sensors it does a pretty good job, but if you get the Autotune Pro or Target Tune option and use the 18mm wideband O2 sensors then it does an awesome job!
To give you an idea, I have the standard 12mm O2 sensors and used "basic" autotune. After a few attuning runs, the bike ran really, really well. But eating to get the absolute maximum out of it, I still took it for a dyno tune and the dyno guy found me another 4hp and 3 ft/lbs.
So the "basic" autotune is good, but not as good as a full dyno tune.
The autotune process is easy. You just set it to autotune, go ride for a bit and then look at the results. Then you re-flash the bike with the data from the autotune which takes about 30 seconds. Rinse and repeat a few times and the bike will run better each time.
It's an excellent bit of kit - you won't regret buying it. But do get it from Fuel Moto as they will support you with free custom maps for life.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
i didn't get mine from fuel moto. had it of been on sale, i might have. i got mine for 429 from:
http://www.ebay.com/itm/251994652639...%3AMEBIDX%3AIT
it's on amazon too for the same price.. but you'll be paying tax.
the visor and mount are both on amazon as well. $35 tops for both
i call dynojet when i have an issue.
i used a pre-load tune that matched my bike. no problems.
great device. good choice sir!
We would be happy to program a Power Vision for your current setup, and when you change components we can provide additional maps as needed. When running Auto Tune you will tune off the current tune for your setup (Fuel Moto tune) and this will adjust the VE tables based on O2 sensor correction, this works very well for fine tuning. Power Vision is very easy to use and we offer unlimited support via email or phone. If you have any additional questions just us know.
In my opinion, FuelMoto is the way to go. They offer a package discount on a stage 1 AC and Powervision. I got my Powervision with mounts/visor and the stage 1 AC for $565 delivered. I think when I was adding up what I'd spend elsewhere, I was within about $30 of FuelMoto's price. The unlimited tunes was definitely worth the $30 to me. These guys are the authority on tunes. FuelMoto has been great to work with and getting a new tune emailed has been an easy process.
wolfman5874
06-25-2016 08:14 AM
claytucc3
05-02-2013 11:23 PM
