Wide glide fender on fat Bob
I want to put a wide glide fender on my 2010 fat Bob . I have seen some post from few years back about this but was wondering if anyone has done this recently. A lot of people who did this with a under fender light strip for wide glide and a turn stop module. One question I have is would which module would you use one for fat bob or a wide glide? Or are they the same ? I think the most tricky part of the conversion is wiring new taillight .. Any help I would appreciate.
Thanks
Thanks
Folks need to know which "under fender light strip" you plan on using (?) There are several available and with different wiring/light configuration.
Is it just a running light? A brake/turn strip? An accent?
To my knowledge the rear wiring harness is the same on the wide vs bob bikes in 2010.
Know what I mean? What do you need a module for and what do you want it to do?
I use a Badlands load equalizer. Corrects the rapid flashing issue...My rear lights (kellermans) have run,brake,and turn in one but I never had to mess with a modulator of any kind. Your just swapping the fender right? Should be fairly easy to do. I'd just chop the struts and get a Voodoo fender and be done.
Wiring advice
Hey all,
I've got a 2012 FB and want to put a post 2010 Wide Glide fender on it, but I'm not sure which wiring jumpers I may need to order. Looking at the 2012 FB and WG wiring for tail lights on the microfiche, it's hard to see what I'll be needing. I know the the 2012 year started the Canbus system for the FB. I want to use a run stop turn setup with possibly LEDs.
Seriously need some help/advice.
Thanks in advance
Thanks in advance
Monteman1971
12-15-2018 06:27 PM
Scott Ballz
01-18-2014 12:49 PM
SAW83
18
08-11-2012 10:45 AM
