Help! Rear Wheel Removal
I'm in the middle of removing the rear wheel on my 06 WG, to replace the tire with a 180. This is my first time at trying this on my own. I've followed the service manual to the T, but now I'm at the point of removing the axle, and the service manual does not mention how to get the axle out. The left nut, washer, and keeper are off. The rear brake is still on the rotor, but I'm assuming that once the axle is out, the wheel and rotor will just rotate out of the caliper.
My main question is, how do I get the axle out? Do I just pound it from the left side with a rubber mallet of some sort? Should the wheel be off the ground when doing this, or should it rest on the ground for support? Do I need to loosen the right side axle nut that is located near the exhaust? My suspension is unbolted on the bottom on both sides, so the swing arm is basically just hanging there with the wheel and drive belt. Thanks for any info. I'm sure once I've done it, it won't be a problem on future rear tire changes.
Jim
Jim
RE: Help! Rear Wheel Removal
If your rear axle is like mine was and I suspect it is then it is probabaly rusted in since the MOCO (and I hope they are watching) Did not put a nickels worth of anti-seize on the axle. It two guys actually 3 1 to hold the bike, 1 holding the piece of wood and mine belt and 1 more swinging a big sledge hammer.
Good luck I ended up taking mine to a local indy and he got it off and chareged me 65 for that and to clean up the axle install new bearing and mount the tire. Now I can get the tire off no problem but it has actaul anti-seize on it now.
Mine has a coating of anti-seize on it, but that sucker won't budge! I'm afraid to beat it too hard, and screw up the end of my axle threads. Anyone have any tips on getting the rear axle out? Bike is only about 6 months old and never ridden in rain, or on salty roads.
I screw the nut back on a few threads then get the axle moving with a dead blow in order to keep the threads in tact. Once the axle is stuck out a bit I use a slide hammer puller like this.
http://www.drillspot.com/products/42...mer-Puller?s=4
Be sure to clean up the axle with some very fine sandpaper or scotchbrite and use anti seize when puting it back together.
From reading these boards I was lucky with my 06 WG. The axle came out fairly easy. I use a punch and a good sized hammer to knock the axle thru. I recommend using a good size punch but of course smaller then the axle dia. and hit the punch driving the axle out with a good sized hammer. If it still doesn't come out try using a air gun on the bolt side to spin it free and repeat hitting the punch.
Oh and I had a floor jack under the tire to keep it up, then when ready I lowered tire from bike. I also left suspension in place, found it totally not needed to be disassembled like instructions suggest.
Wish you well,
Josh
Wish you well,
Josh
Whatever method you use, do make sure you coat the axle with anti-seize before putting it back through. Take care to wipe it down once it is out, run your hand over it to make sure there are no burs (light sanding should remove them) and then take note of where the axle spacers go. Reverse the process and you're on your way and you'll know that the axle has been installed properly.
Once you get the hang of it, it shouldn't take more than10-15minutesto take the wheel off next time including getting the bike jacked up, etc.
