The FXRT / FXRP "Style" Dyna Fairing Thread
Old 02-26-2018 | 10:49 AM
BFMCdyna's Avatar
BFMCdyna
Originally Posted by leeinmemphis
Only thing I need to do is find a better way to mount the front turn signals so that they are more visible and possible add a klockwerks windshield.
I got the idea from another member on this thread to mount my turn signals to the bottom of the fairing. The RWD fairing's design makes it easy to mount down there and it gives good visibility. I just drilled a hole and used a standoff with the mount. Scroll up to see pics of my bike.
  #312
Old 02-26-2018 | 03:55 PM
MSgt1371's Avatar
MSgt1371
Veteran: Marine Corp
Originally Posted by JoN_JoN
Which mounts and what hard bags did you use? I'm wanting to do this same setup on my 15 Bob and can't seem to decide on which mounts to go with for the bags. Seems like a lot of them leave a huge gap between the bags and the fender that I'm not a fan of.
Used switchback bags with a custom mount that fits under the fender and allows me to use the switchback mounting hardware
  #313
Old 02-26-2018 | 08:54 PM
leeinmemphis's Avatar
leeinmemphis
Any chance you have any close up shots or shots from the front with the lights on?
  #314
Old 02-27-2018 | 10:44 AM
BFMCdyna's Avatar
BFMCdyna
Let me know if you want a closer, close-up
  #315
Old 02-27-2018 | 09:02 PM
leeinmemphis
question for you guys with the klockwerks windshield. Do you find much improvement over the standard windshield the fairings come with. I don't really have much wind turbulence with the shield it came with but if I could get it about 3" higher then the wind will be going right over my head.
  #316
Old 02-28-2018 | 08:51 PM
leeinmemphis
well I went ahead and ordered the klockwerks shield. I'll be sure to post up pics/thoughts after I have a chance to ride it a little.
  #317
Old 02-28-2018 | 09:03 PM
rideon's Avatar
rideon
I have the klockwerks windshield and it works pretty good. I’m 6’2” and I have a calm pocket of air but it’s windy, not buffeting air though. I also have lowers which make a difference as well. The fxrt fairing is a good design and seems to work better than the road glide fairing on my previous bike.
  #318
Old 03-03-2018 | 09:13 AM
FlyingDutchman2308's Avatar
FlyingDutchman2308
6th Gear
Default Vacant House Fairing
I have a Vacant House fairing for a 2002 FXDX that I am getting build. Motor work will be done to make it a 107ci, chain drive, considering a Baker GrudgeBox, etc.
Looking for the Lowers that fit perfectly with the Vacant House fairing. Need lowers that fit perfect, have not found any yet, looking for suggestions and recommendations on the build and lowers.
The look I am trying to get to is as in the pic.
Attached Thumbnails The FXRT / FXRP "Style" Dyna Fairing Thread-white-dyna.jpg
Lu (04-12-2020)
  #319
Old 03-03-2018 | 09:22 AM
rideon's Avatar
rideon
I have a RWD fairing with BMC lowers and the fit is spot on. I have the Mad Jap Customs brackets on the lowers, which have a fair bit of adjustment. Looks like the white bike has the same brackets on the lowers.
  #320
Old 03-03-2018 | 09:27 AM
FlyingDutchman2308
6th Gear
Thanks Rideon, I was told that the lower part of the Vacant House fairings are a little different, I just want to make sure when I buy some they are the correct fit.
Quick Reply: The FXRT / FXRP "Style" Dyna Fairing Thread
