New Low Rider S
Old 05-13-2016, 12:34 PM
Tritty's Avatar
Tritty
Tritty is offline
6th Gear
For those of you that raised your bars, how much slack did you find in the cables? I got 7.5" tall bars and 1.5" risers. The stock risers are around 5.5" with a flat bar. So my new setup should be around 3.5" taller. But I'm thinking about going 4" total more narrow so around 2" per side. Just wondering if anyone who's done their bars needed to extend the fly by wire and other controls? By my calculations I need around 2" of slack in the stock wires.
  #962
Old 05-13-2016, 03:27 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,538 Likes on 2,145 Posts
Plenty of wiring slack. Clutch cable is tightest, brake second. 8" total rise currently on mine, and my clutch cable is pretty much at the limit. Brake may be able to squeeze another inch or two.
  #963
Old 05-13-2016, 04:06 PM
Tritty's Avatar
Tritty
Tritty is offline
6th Gear
Thanks for the info. I'll hold off on ordering any extensions then. I'll post pics of how it looks when I'm done.
  #964
Old 05-13-2016, 08:47 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,210 Likes on 3,382 Posts
Originally Posted by deewright
Owners manual, where can I get one of those from.
You need to hammer your dealer, it is part of the package.
But, that pic I posted for you is right from the HD website, brother.
  #965
Old 05-14-2016, 01:54 AM
SlowriderInOz's Avatar
SlowriderInOz
SlowriderInOz is offline
Default Engine Temps
I decided to log some engine temperatures today. I plugged in the FP3 and stuck my iPhone onto the inside of the speed screen with some strong velcro to see the numbers.
My drive train is stock with the stock ECU map and only around 250 miles on it.
This is what I recorded.
At 70mph with no traffic. 235 - 245F
at 50mph or following a car 251F
At idle after about 1hour of riding the temp went up to 280F.
EITMS was disabled.
I'll do some more runs after run in and turn the EITMS on to see what temp it cuts in.
  #966
Old 05-14-2016, 07:05 AM
Yukon42's Avatar
Yukon42
Yukon42 is offline
EITMS was disabled.
Good info! I'm keeping mine stock (at least for the time being) and was wondering about the temps. Looks like a jagg oil cooler is called for. Looking at a fan assisted frame mounted unit for best cooling performance.
  #967
Old 05-14-2016, 08:24 AM
Gearhead88's Avatar
Gearhead88
Gearhead88 is offline
I've had mine just over a week , not a lot of miles on it yet due to working , weather and changing up a few items . In the three hours or so that I have spent riding it , I have noticed that it does run hot.
I have ordered an oil cooler and plan on having it tuned after break in / first service.
I've got a Screamin Eagle super tuner set aside for that .
So far I'm really enjoying the bike , handling , power , ride quality and looks !!
As mentioned , I've done a few minor changes.......
Screamin Eagle slip on mufflers , I did not want it to be too loud , the level and sound quality is just right.
I bought an accessory seat from my dealer to use when needed , the low profile leather one they used on CVO Dyna's.
Added passenger pegs .
I bought the highway peg mount kit too , that stuff is at the powder coaters right now.
Changed the stock offset footpegs to straight up 0 offset , nothing fancy , just standard issue Harley rubber pegs is fine with me.
Smoked signal lenses and amber bulbs up front.
Flush mount black fuel caps.
Ribbed clutch cover and timer cover.
I bought one of those licence plate brackets from Great bike Gear , modified it a bit , painted it textured black and installed it with a small L.E.D. tail/brake light . In Canada , these bikes come with a not so attractive licence plate / tail light arrangement , it still has the signal light/ running light/ brake lights that are standard issue , they're just moved back on to the new licence plate bracket. It looks much better now.
I've also installed docking hardware so I can use the gloss black sissy bar / backrest that I bought with my accessory package.
I'm gonna get out and ride this weekend.
  #968
Old 05-14-2016, 11:53 AM
cudacrazy73's Avatar
cudacrazy73
cudacrazy73 is offline
I've got a Screamin Eagle super tuner set aside for that . I'm doing the oil cooler @ first service also. Does our bike come stock with the SE tuner? That's what my dealer said...
I bought an accessory seat from my dealer to use when needed , the low profile leather one they used on CVO Dyna's. I almost got that same seat Can't wait to see how it would have looked.
  #969
Old 05-14-2016, 12:20 PM
djorgensen3's Avatar
djorgensen3
djorgensen3 is offline
I bought and installed a new seat. I put on a Mustand Wide Tripper with matching passenger pillion. I ordered it with the diamond stitch pattern. The passenger pillion is a little wider than the fender but the wife likes it so it stays. It definitely moved me back 2+ inches which is good for my long arms and legs.
File Type: jpeg
  #970
Old 05-14-2016, 12:23 PM
djorgensen3
File Type: jpg
Quick Reply: New Low Rider S
