New Low Rider S
#2172
I see a bunch of Lucky Dave's and BMC/Borbin Wall seats on here.
What are the differences between them, other than the Wall having a, you know, bigger wall bit? I don't really have a chance to go and sit on one living in the *** end of Australia.
Currently using a sundowner 2-up and it seems to raise me up and maybe forward a bit compared to the stock crappo seat.
The Lucky Dave's seems to be more comfortable since it has the gel inserts?
#2174
#2175
That wall seat looks good on there! How tall are you? The seat doesn't look as tall in the back as I thought (love corbins, but looked like a sore dick to me). Was thinking about a SpeedFam seat, but I dunno... I've had three great experiences with Corbin over the years, its hard to go away from them.
Oh yea. im 5'9' by the way. The seat sits you down slightly lower than stock. I run 8" big als kickback risers and 4.5" kdub bars (also big als)
Those speedfam seats look to be personalized C&C seats and ive heard nothing but good things about them!
--break break--
updated photos with Deviant fabrications full fender, laydown plate, and low pro smoke Custom Dynamics tail light with integrated turn sigs. Really happy I didnt need to bother reflashing BCM. everything works as they should. Im proud to say that I think im done doing things to it for a while now.
The great thing about this page, is that yes we all have the same bike. The beauty of it is seeing what we make of it to fit our needs and lifestyle whether its form and function or looks. I prefer function..
Last edited by dyna-petey; 04-03-2017 at 06:14 AM. Reason: forgot to add info on the seat.
#2176
dyna-petey (04-03-2017)
#2178
I got my 117" together finally
Attachment 505204
132 hp 138 ft lbs on the break in tune, after I get some miles on it it'll be back on.
SE 117" Kit (- minus pistons, lifters, pushrods and cams)
Suburban Speed Mahle 6cc Domed Pistons
10.8:1 Compression
TMan Heads (2.16 intake/1.63 exhaust)
TMan .660SM Cams
TMan Adjustable Pushrods
S&S Lifters (HL2T Limiter)
S&S Roller Rockers
SE Heavy Breather Elite
Crank Pro Plugged and welded by Darkhorse
Timken Conversion
RB Racing Pro Stock Challenge
Barnett Scorpion Clutch
SERT
Attachment 505204
10.8:1 Compression
TMan .660SM Cams
S&S Roller Rockers
Timken Conversion
SERT
huggies (04-07-2017)
#2179
LePera Daytona Installation 2016 low rider S
Just took delivery of new le pera Daytona sport seat, have removed the stock single seat and removed the bolt from the rear locating hole on the fender, however, whilst threaded this doesn't have a spacer sitting proud of the paintwork but is located by a plastic moulding under the fender, my question is it possible to move the spacer from the front locating hole and if so how?
#2180
