New Low Rider S
#1251
#1252
#1253
hey bud HD now makes a kit for your Low Rider S. This is for 14" rise but you just gotta go to your local dealer and tell them it should be on their May HD catalog. Part #s: 41800438 and 41800078. One is for the upper brake lines and the other one is for the lower brake lines with the junction block for your ABS.
#1254
#1256
Big bear say their ABS block will be $150... shame I'm all the way in the UK!
#1257
How to remove pins from this connector?
Hi, I'm trying to remove the pins from this connector so I can install the Great Bike Gear rear signal/license plate kit that some of you have already done. I can't seem to figure out how to remove the pins. Any help would be appreciated. Thanks. (I got the pictures from another member who did a relocate on a late model street bob, so I assume they are the same for the turn signals.)
#1259
Has anyone tried fitting the small solo rack on the back along with a set of LeatherPro FXDXT bags? Can you take the bags off with the rack in place?
I had a solo rack and gave it away when I thought that I could get the detachable rack on with the bags. Guess I got ahead of myself...
Thanks.
Chonk
Thanks.
Chonk
#1260
The following 2 users liked this post by Mchad:
Hellbilly562 (07-19-2016),
jcanrun (07-19-2016)
