Bar mounted front turn signals
Old 01-10-2016 | 08:14 PM
scoledawg03's Avatar
scoledawg03
6th Gear
Default Bar mounted front turn signals
I have a 2006 FXDC with eternal wiring. Planning to go with internally wired T-bars. My question is, if I want to keep my turns on the bars, do I have to change out the lower switch housings to accommodate the turn signal wires? If so, does anyone have a part number for those? Thanks in advance.
Old 01-10-2016 | 09:39 PM
JohnMn's Avatar
JohnMn
No, you'll need wires coming back up for the signals,, and maybe another hole.
The switch wires go down to the harness routed to the turn signal flasher circuit and come back out to feed the signals.
Old 01-11-2016 | 12:11 AM
archergodwin's Avatar
archergodwin
When I did my internal wiring, I didn't have to change the housings to anything different... although I did go with all chrome switches/housings...
Tony Underhill
Electrical/Lighting/Alarm
04-20-2017 08:07 AM
jmerchant.1
06-07-2015 08:50 PM
CB024
05-16-2013 11:23 PM
plumblocal1
07-10-2008 11:18 PM
imboden
04-06-2006 01:48 AM
Quick Reply: Bar mounted front turn signals
