40 amp regulator with 38 amp stator
Old 01-07-2016 | 12:40 PM
Deathbat9's Avatar
Deathbat9
Default 40 amp regulator with 38 amp stator
Replacing regulator and stator, would running a 40 amp regulator with a 38 amp stator be fine. Have an 06 dyna. Thank you
Old 01-07-2016 | 01:00 PM
Jackie Paper's Avatar
Jackie Paper
In my 2008 Dyna manual, it describes the regulator as 35-50 AMPS. I would put the correct part number on there. We talking OEM or aftermarket?
Old 01-07-2016 | 01:07 PM
Deathbat9's Avatar
Deathbat9
Drag after market, ordered them based off year and model of my motorcycle.
Old 01-09-2016 | 12:24 PM
archergodwin's Avatar
archergodwin
Having a regulator, with a higher capacity than your stator/rotor, is fine. The reverse would not be good.
Just need to make sure of the phases... is it a 2-phase or 3-phase alternator setup? ( 2 conductor wire or 3 conductor wire )
Old 01-09-2016 | 12:28 PM
Jackie Paper
Started to bring the point of a mated match but not sure how to sinse I have been trying to figure the phase out even for a Harley OEM for a long time. I had assumed 2 wire was two phase but another user says no. Know most places refer to the old two wire as single phase... Might want to read here. If you go aftermarket, they should be paired. Going OEM and part number will always work.
https://www.hdforums.com/forum/elect...l#post14728191
Old 01-09-2016 | 12:42 PM
Deathbat9's Avatar
Deathbat9
Thanks everyone for the input ended up just going with 40356-06b kit from Harley.
falconbrother
EVO
33
08-20-2023 08:55 AM
SoftailCustom83
08-10-2013 02:45 PM
sonnydaze
07-16-2013 04:38 PM
joearizona
07-21-2008 06:00 PM
sobrbiker883
02-01-2007 03:32 PM
Quick Reply: 40 amp regulator with 38 amp stator
