Running wires inside the swingarm. Bad idea?
I'm going to be wiring the license plate light and I am considering drilling a few little (1/8" or smaller) holes in the swingarm to get the leads up to the fuse box.
I obviously won't be able to support the wire inside the tube. Will the vibration be a problem?
I also would worry about stretching the wire and maybe even shorting out on the point of entry/exit once the insulation wore away.
What I did was cover the full length of the wires in black heat shrink. Heated the whole length really good to keep the wire as minimal as possible. Then I just ran the wire along the bottom/wheelside of the swingarm and used black zipties to hold the wire in place. Can hardly tell anything is there.
These mounting pads work perfect, but I have found that the two sided tape on them tend to rot and fall apart when they get wet and dry constantly. I use these a lot at work, and have found that pulling of the standard tape, and adding a square of this tape (link below) works perfect. The outdoor tape is strong enough that I bent a stainless cabinet trying to get one off that I applied two years ago.
http://www.homedepot.com/p/3M-Scotch...1-DC/100575385
