Single headlight for fat bob
Did this on my street bob not long ago. The main difference will be the wiring end. Still fairly easy, just many ways to go about it.
Also I tried 2 different mounting blocks, but ended up making my own to get the placement I was looking for.
https://www.hdforums.com/forum/dyna-...ht-bucket.html
I put a 2004 Fat Boy head lamp on my 2009 Superglide,, No Problem.
It fit the existing mounting block just fine.
I looked at Ronnies parts and your block is different because of the duely, but the FXD's simple block mounts the same,, a single bolt under the lower tree.
Just find the parts it'll work,, as long as you listen to Ironcleveland;
Valerie Snetzinger
01-30-2017 11:04 AM
hellbob37
06-16-2012 12:19 AM
