Easy Brackets or Edge Brackets?
Easy Brackets. The Edge Brackets, used to be called Ghost Brackets are more of a universal fit product. Vikings quick release Brackets appear to be very similar to the Edge Brackets, if not the same item.
FYI, the Easy Brackets + the required docking hardware (you can buy the Harley branded hardware or save by going with Vtwin Mfg, etc ) will create a mounting surface for bags which sits just outside the shock bodies on most Dynas. So the "shock cutout" bags offered by Viking aren't really necessary or even desirable when using Easy Brackets
The Easy Brackets need a fairly wide mounting surface and the shock cutout can prevent you from mounting the bag where you want it. You may end up with the bag mounted higher up or tipped at a weird angle to provide enough surface to mount to the Easy Brackets. So you are much better off going with flat-backed bags.
I bought my easy brackets from http://www.greatbikegear.com/ and I recommend them.
Bob Zamzow from greatbikegear was very helpful to me also in selecting leatherworks bag.
