Just installed 200mm rear tire on my street bob :)
Old 11-17-2015, 07:34 AM
2015 Harley Davidson Street Bob Guy's Avatar
2015 Harley Davidson Street Bob Guy is offline
Default Just installed 200mm rear tire on my street bob :)
Just replaced my 180mm rear tire with a new 200mm rear tire without having to mod my bike or use spacers or what ever I didn't have to buy wider mud guard
The 200mm rear tire fits right on my 2015 oem 17x4.5 rim
EDIT: now that i have done a few 100 miles on my bike the 200mm tire is a charm
So if you own a 2013+ street bob and you want 200mm tire? Just put it on there is no need for spacers or anything else
If the tire is rubbing against the wall after the installation it could only mean the engine isn't mounted straight so all you have to do is realign the engine to get both side of your tire cleared of the mud guard.
My mechanic is freaking awesome he did it for me if you guys are in Perth Australia and you want a very good mechanic to work on your bike give Ando a call
Last edited by 2015 Harley Davidson Street Bob Guy; 11-18-2015 at 05:58 AM. Reason: Sharing photos
Old 11-17-2015, 10:22 AM
Dyna rider 78's Avatar
Dyna rider 78
Dyna rider 78 is offline
Do you have any pics from the rear, curious to see how it looks?
Old 11-17-2015, 10:38 AM
WMX124's Avatar
WMX124
WMX124 is offline
Originally Posted by 2015 Harley Davidson Street Bob Guy
There is only 1 down side to this - the rim is only 4.5" so my 200mm rear tire lookeed like a 180mm rear tire that i had on before.
My suggest is if you want the bike to look like it's got a 200mm rear tire you will need to buy 5.5" to 6" rim.
Nailed it.
You actually reduced your contact patch by running the 200 on the stock rim. This will cause premature tire wear.
Old 11-17-2015, 10:43 AM
RR611's Avatar
RR611
RR611 is offline
Pics or it didn't happen.
Old 11-17-2015, 11:25 AM
nevil's Avatar
nevil
nevil is offline
Received 1,034 Likes on 773 Posts
In conclusion I prefer the 180mm rear tire it feels great and rides good compared to the 200mm.
So, bigger isn't always better. Just bigger.
Old 11-17-2015, 11:45 AM
slyedog's Avatar
slyedog
slyedog is offline
All tire manufacturers have a minimum and maximum rim width. So if you are too narrow there may be some saftey issues such as a weak side wall or as stated the contact portion is compromised. Then there is max width where people actually stretch tires. That's what the lowriders with the tiny 13"wires do for example. But as you realized the 180 felt better as it properly fits your rim. Don't be fooled though. With my 18x5.5 I can't get my index finger between the belt and tire so a 200 in a Metzler won't be going on my bike.
Old 11-17-2015, 01:37 PM
AKFXD's Avatar
AKFXD
AKFXD is offline
I'm not sure you should even run a 180 on a 4.5" rim.
I put one on and it measured just over 150mm.
Your 200 is probably under 170 and if that is the case, you would probably be happier with an actual 170.
I ordered a 6" wide rim to lace onto my hub so my 180 will actually be 180 and the correct shape.
Old 11-17-2015, 02:37 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
Good to know you don't like it on the small rim though.
Old 11-17-2015, 02:53 PM
edit: the 200mm rides like a charm
Old 11-17-2015, 03:03 PM
AKFXD's Avatar
AKFXD
AKFXD is offline
Originally Posted by BigDogIdaho
180/55 17 on a 4.5" rim
Quick Reply: Just installed 200mm rear tire on my street bob :)
