Is it possible to lower my bike without replacing front suspension?
As per manual the "fork tubes should protrude above the triple clamp .0450-0.500 in. (11.4-12.7mm)" So just loosen the pinch bolts and slide the tubes up approx. 1" and tighten pinch bolts to 30-35 ft. Lbs. (41-48Nm)
That will get you "close to the 1 " drop you asked about. Then make sure you will not "bottom" on anything when your suspension is compressed.
You'll have to watch pulling the fork tubes up in the tripple tree if you have stock handle bars. Not a whole lot of room but some.
And if you slide the tubes up 1in, thats not going to make your front end sit a full inch lower because the forks sit at an angle and not perpendicular to the ground.
Really the only way to do it, is with a lowering kit that includes shorter springs and they're only arond $100. But if you wanted to, you could try cutting down your springs a touch. While certainly not optimal for handling (lowering doesnt help handling of these bikes at all anyways, only hurts) it would work.
