180 tire on harley switchblade wheel?
I have a set of switch blade mag wheels on my 06 streetbob. The rear is a 17x5.5 I believe. Is a 200 tire too much? Should I stick to a 180? I changed the bolts for my rear fender brackets, so I do have alot more clearance now, it currently has a 160 on it. I'm pretty new to this so any help will be appreciated, thank you.
A pic of my bike
A pic of my bike
If I'm not mistaken, your rear wheel is 4.5" not 5.5". According to manufacturer "recommendations" the only 3 180 tires made for a 4.5" wheel are the harley Dunlop, a Michelin scorcher, and Pirelli night dragon. You "CAN" put any size tire on that you can get to fit. There are threads of people going as large as a 190 on the 4.5" rim and stating no troubles. I don't know if I've seen people go to 200 on a 4.5" wheel though.
Thank you for link, QC, but that link is for harleys, with factory laced wire wheels. I have a set of harley switchblades, and I measured the rear wheel at 5.5.
According to this chart, no:
http://api.viglink.com/api/click?for...%2FProduct.htm
Dyna Switchback (2) FLD 2012-2015 18x3.0 130/70-18 21x3.5 120/70-21 17x4.5 160/70-17 18x5.5 180/55-18
The size I highlighted is max tire size for a 18 X 5.5 wheel.
But as the other poster said, You can mount anything to anything if you can get it to fit. Good luck.
Edited after relooking at the chart.
I have a switchblade wheel, not a switchback wheel. It's a 10 spoke mag wheel, I do like the switchback wheels, though. Thank you for your help QC, I'm still figuring out what to do, but it's not really a priority. I'm just playing around with ideas. Thanks again.
The size I highlighted is max tire size for a 18 X 5.5 H-D Switchback wheel.
Either way, I would feel comfortable running a 180 tire on a 4.5in wide wheel but Nothing wider. I'm currently running a 170/60 night dragon on mine, and the fit is perfect but it actually looks smaller than a 160/70 tire because it is a tiny bit shorter. I'm thinking about going to the 180 night dragon next.
Received 5,744 Likes
