How about some Dyno numbers
Old 05-06-2007, 03:28 AM
Macs06WG's Avatar
Macs06WG
Macs06WG is offline
Default How about some Dyno numbers
i was wondering if some of you guys would post what you have done to your motor and the numbers it made i think it will help others that are looking to do motor work get a base line.
2006 wideglide
95"
Hi Comp SE forged pistions
SE 257 cam
Custom head work
Adj Push rods
Bassani Pro Streets
SE air filter kit
Power Commander
Hp 108.9 TQ 103.8
Old 05-07-2007, 08:50 AM
West_Tn_Biker's Avatar
West_Tn_Biker
West_Tn_Biker is offline
Default RE: How about some Dyno numbers
I have an 03 wide glide
88 ci
Stage 1
Vance and Hines Big Radius
SE 6200 ignition module
Carb has been rejetted
78.95 hp
85.05 torque
Am installing SE211 cams now and should have those numbers by the end of the week
Gill
Old 05-07-2007, 09:17 AM
hd2000's Avatar
hd2000
hd2000 is offline
2000 wide glide with big shot staggereds put up 92hp and 93 for torque.
Old 05-07-2007, 10:10 AM
nidan's Avatar
nidan
nidan is offline
Mac that's an SE 257 not 275 isn't it? or did thay come out with a new one?
Old 05-07-2007, 03:52 PM
GREENOHAWK69's Avatar
GREENOHAWK69
GREENOHAWK69 is offline
'97 Wide Glide
80" Evo motor
SE Performance Heads (9.5:1 compression ratio)
Andrews cams
Thunderheader 2-into-1 exhaust
SE 6000 RPM ignition module
79 HP / 87 TQ
Top speed - 125 mph > so far [sm=badbadbad.gif]
Buddy hasa Softail with the TC 88........1st and 2nd we're even, I walk himin 3rd.
Old 05-07-2007, 04:30 PM
Macs06WG's Avatar
Macs06WG
Macs06WG is offline
ORIGINAL: nidan
sorry ya its a 257
Old 05-07-2007, 10:38 PM
thrillseeker's Avatar
thrillseeker
thrillseeker is offline
2005 WG
SE 1550 Stage I kit (breather, stock cam, 95", which pistons I have no idea)
V&H Pro Pipe
PCIII
80hp/88tq
Old 05-07-2007, 10:53 PM
07fxdwg's Avatar
07fxdwg
07fxdwg is offline
2007 Wide Glide
SE air cleaner
Python Staggered Duals
SERT
SE 103"
SE Forged pistons
SE 251 cams
SE valve springs
Stainless high flow valves
SE adj pushrods
97.77 hp 104.45 tq
Old 05-07-2007, 11:33 PM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
SE high flow air, VH straightshots HS and a PC III
Old 05-08-2007, 03:15 AM
harlo666's Avatar
harlo666
harlo666 is offline
just got mine dynoed along with the 1000 mile service
78.9hp/93.4tq
2007 dyna street bob
ness big sucker
cobra pro hp 2into1
want 100/100 by next summer or i will be a sad little fella
Quick Reply: How about some Dyno numbers
