Grinding flat the seams on a tank. Are they good and solid?
Old 10-20-2015 | 08:47 PM
cggorman's Avatar
cggorman
Default Grinding flat the seams on a tank. Are they good and solid?
I'm assuming they will grind flat with no problem, but before I get there only to discover spotty welds, I thought I would ask. I'd rather not start welding on it to fix pinholes. My welding skills are the suck.
Old 10-22-2015 | 11:52 AM
jaxdwg's Avatar
jaxdwg
I think --- bad idea
Old 10-22-2015 | 02:07 PM
cggorman's Avatar
cggorman
Does H-D sell any modern Big Twin bikes without a tank bib to hide the seams?
Old 10-22-2015 | 08:57 PM
ToffeeBrown's Avatar
ToffeeBrown
my 05 FXDL has a center dash down the middle, but there is no external weld underneath it. There is, however, a recess riveted into the tank underneath the speedo/tach, but that shouldn't be an issue for what I think you are trying to do.
Old 10-22-2015 | 09:01 PM
cggorman's Avatar
cggorman
No. I'll leave the console but I'd like to eliminate the tank bib without having to look at the welds.
Old 10-22-2015 | 09:41 PM
CJeep's Avatar
CJeep
Yes. My FXD has no visible seam under the console. But of course, that has the center fuel fill and speedo on the bars. Doubt that's any help to you, but since you asked . . .
Old 10-23-2015 | 02:05 AM
ToffeeBrown
Mine is similar, just with the different dash set up
Old 10-23-2015 | 10:36 AM
cggorman's Avatar
cggorman
Interesting... I wonder if the manufacturing process changed when they went to FI or if they just grind certain models. I suppose I'll take mine off and grind it. If it looks pinholey, I'll have it TIG welded.
Old 10-24-2015 | 12:11 AM
NORTY FLATZ's Avatar
NORTY FLATZ
They're "good & solid" until you molest them...
Old 10-24-2015 | 12:27 AM
JustDave13's Avatar
JustDave13
Veteran: Marine Corp
I don't see any problem dressing the weld up with a sander, a good weld would have 100% penetration
Quick Reply: Grinding flat the seams on a tank. Are they good and solid?
