flat tire question
Old 09-27-2015, 03:39 PM
canadayman's Avatar
canadayman
canadayman is offline
Default flat tire question
i picked something up in back tire and my question is can a motorcycle tire be fixed or should i play it safe and get a new one
the hole is the size of a 16 penny nail want to be safe and was wondering if it is like a car tire and just put a patch in it
Old 09-27-2015, 03:43 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,411 Likes on 2,032 Posts
You will get many yes/no answers to this question. I say no problem especially since a Dyna uses a tube anyway.
Old 09-27-2015, 05:00 PM
Jonesee's Avatar
Jonesee
Jonesee is offline
Super Glides don't run tubes.
To the OP:
Plug it and roll on. I've run 1000's and 1000's of miles on plugged tires
Old 09-27-2015, 05:08 PM
perki48's Avatar
perki48
perki48 is offline
To the OP:
OOPS, missed that, Thanks for clearing that up.
Old 09-27-2015, 08:50 PM
CityRider76's Avatar
CityRider76
CityRider76 is offline
6th Gear
Like others have said, just plug it. My last two tires were punctured almost immediately after purchase. I still put a few thousand on each before I finally replaced them.
Old 09-27-2015, 08:58 PM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
It can be safely plugged, but personally, I wouldn't be able to trust the tire after that. If I could afford it, I would buy a new one just for peace of mind.
Old 09-27-2015, 11:40 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
Patch it and go.
Old 09-27-2015, 11:48 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,750 Likes on 3,110 Posts
If the tread is more than 50% worn, I'd replace it. If I were taking a ride 2-up in the Calif desert in the summertime...
Old 09-28-2015, 12:01 AM
bigbadpoppa's Avatar
bigbadpoppa
bigbadpoppa is offline
Plug it and be done with it.
I've plugged so many tires in the past without problems even on my race bikes. If they can be plugged, I wouldn't even blink twice with a cruiser tire which takes much less of a load.
Old 09-28-2015, 07:36 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
To the OP:
What he said. The one thing I do when I put in a plug: I keep a can of vulcanizing cement and dip the string-type plug in it before I put it in and I twist it several turns before I pull out the tool. Works good, lasts a long time
Quick Reply: flat tire question
