Security light
If the red security light comes on and stays on, it is showing a BCM error. Check your error codes (check engine codes), should tell you what the problem is.
Been trying to search the forum.
I installed an aftermarket LED headlight and now I have a check engine light and the red dot on the dash illuminated.
I lost left turn signal, horn, and high beams.
I triple checked wiring and the dealer told me to leave the hazards on with ignition on but bike not running. I think I am going to take it in to see if clearing the code will help.
