Tracker die LED headlight
Old 09-08-2015, 09:03 PM
ToffeeBrown's Avatar
ToffeeBrown
ToffeeBrown is offline
Default Tracker die LED headlight
http://trackerdie.myshopify.com/prod...-led-light-bar
Just got one of these to throw on my new midglide. Killer light. Im not sure how to post pictures here, but I will when i figure it out. The old bates style headlight I had is going on the chopper!
Old 09-08-2015, 10:38 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
Makes me think of Mad Max when I see it. Think it would look good on the right bike!
Old 09-08-2015, 10:48 PM
ToffeeBrown
I really like it. At first, I was worried. Then I realized that form follows function and it is a SERIOUS light.
Old 09-08-2015, 10:49 PM
BigDogIdaho
I'm sure that thing DUMPS out the light! Looking forward to seeing some pics!
Old 09-08-2015, 10:54 PM
ToffeeBrown
Ya it really does. Ill try and learn how to do pictures tomorrow and hook it up. Only issue is that it doesn't have high/low, but I left my light on high anyways, so I suppose it isn't too big of a deal.
Old 09-08-2015, 11:40 PM
PanHeadRich's Avatar
PanHeadRich
PanHeadRich is offline
YIKES!!! Not much good as a headlight without a hi/lo beam IMO. But I posted the pics for you anyway.
Old 09-09-2015, 12:26 AM
Lama's Avatar
Lama
Lama is offline
Old 09-09-2015, 06:04 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
Originally Posted by Lama
looks like the same light at less than half price
Old 09-09-2015, 06:06 AM
ToffeeBrown
excellent work!
Old 09-09-2015, 07:02 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
It won't work as a replacement for the headlight if you drive at night (way too bright), but works well for daytime, or with the stock headlight, wired to the high-beam circuit.
Here's a smaller one that also works quite well for auxiliary lighting. Bolts easily to the bottom of the lower triple clamp, between the forks. 22 bucks for two of 'em.
Amazon.com: Zone Tech 2x 18w Slim Flood Beam LED Work Light ATV 4X4 Off Road Light 1800 Lumen 6500K 90 Degree Waterproof Light: Automotive Amazon.com: Zone Tech 2x 18w Slim Flood Beam LED Work Light ATV 4X4 Off Road Light 1800 Lumen 6500K 90 Degree Waterproof Light: Automotive
Quick Reply: Tracker die LED headlight
