Possible Wheel change? Will they fit?
Your questions depends on a few things, years for your bike and wheels, bearing sizes changed a couple times, so you need to do a little research on axle and bearing sizes.
It may very well be an easy swap, I run a 17" 07 Softail rear wheel on my 05 Dyna, everything needed was in the install kit HD sells. (swapped from 16" to 17")
