Installing a 2 into 1 night stick muffler
Old 09-01-2015 | 10:37 PM
Highgrade's Avatar
Highgrade
Default Installing a 2 into 1 night stick muffler
I'm planning on installing a Screaming Eagle Night Stick Muffler on my FLD and just wondered if any one has done this and good provide any tips.
Also do you have to buy the muffler clamp kit or can you reuse the original clamp?
Old 09-01-2015 | 10:48 PM
maddghost's Avatar
maddghost
Whatever you need that is not part of the original setup should be included from HD. The best place to inquire will be at the parts counter.
I'm not sure what a nightstick exhaust is to be honest, but I'm guessing it's a slipon with only one pipe converting your 2/2 to a 2/1.
slipons are real simple to mount. if someone tells you that you need a new torca clamp it is bullstich.....trust me!
Old 09-01-2015 | 11:29 PM
JohnMn's Avatar
JohnMn
Depends on the internal rust,, if it's bad and/or the clamp ain't shiny enough for ya,, get a new one,, other wise a clamp is a clamp. It's a good bet to get a new bolt and nut, but a hardware store can help ya with that.
Old 09-02-2015 | 05:04 AM
misfitJason's Avatar
misfitJason
If you do need a clamp take your old one to oreillys or autozone and get one there for about 6-11 dollars
Old 09-02-2015 | 07:22 AM
hell hound's Avatar
hell hound
i have the nightstick on my lowrider. no need to buy a new clamp in my opinion.
Nightstick is a SE slip on, but it is made by Supertrapp and uses thier disk technology
you can remove or add disk and can use different end caps.
mine is the stock end caps and disks
rwven
2014-2023 Touring Models
11
09-18-2023 07:17 PM
rodney123456
05-16-2015 10:53 AM
El Chiguete
03-13-2014 06:10 PM
jamala00
10-04-2011 02:20 AM
Storm_law
05-18-2010 06:38 AM
Quick Reply: Installing a 2 into 1 night stick muffler
