Aftermarket Turn signals
Old 08-27-2015, 01:17 PM
emperor wurm's Avatar
emperor wurm
emperor wurm is offline
Default Aftermarket Turn signals
Hey, I want to change my front turn signals to something smaller and sleeker than the bulky stock turn signals. between the internet and ebay I have not been able to find anything I like. If I dont find something I will more that likely just eliminate the turn signals...but this is my first "Big" Harley and I kind of want it to be street legal....any how, if you have pictures of your aftermarket FRONT turn signals, please post them, thanks.
Old 08-27-2015, 01:28 PM
JohnMn's Avatar
JohnMn
JohnMn is offline
Try searching again and use the word "mini",,,
Old 08-27-2015, 02:54 PM
Reindeer's Avatar
Reindeer
Reindeer is offline
I have these units from Joker Machine. I'm sure they're not as visible as the stock lights, but they're better than nothing.
Old 08-27-2015, 05:33 PM
dpoll995's Avatar
dpoll995
dpoll995 is offline
Custom dynamics truwrapz. They are pretty small and really bright and have a lifetime warranty.
http://www.customdynamics.com/truflex_truwraps.htm
Old 08-27-2015, 05:48 PM
kontiki's Avatar
kontiki
kontiki is offline
Received 2,279 Likes on 1,155 Posts
I notice the bottom of the turn-sig light housing just touches the gas cap and the fuel gauge on my low rider when the bar is turned at the extreme left or right positions.
So I'd like to find a little smaller and/or more stylish front turn lights myself. These are basically the same thing that was on my Sportster and didn't like those either.
Old 08-27-2015, 05:51 PM
kontiki's Avatar
kontiki
kontiki is offline
I sorta like that - except maybe with them turned to the outside instead of inside to give better separation.
Old 08-27-2015, 11:48 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
bar end sigals, often times people don't even notive them till the come on.
http://www.kellermann-online.com/en/...gruppe/bl_1000
Old 08-28-2015, 05:12 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Running these on the outside is how the lights are intended to be used by design, many people do exactly what the guy that posted the pic did and swap sides to run the lights inside for a sleek look.
Old 08-28-2015, 04:25 PM
kontiki's Avatar
kontiki
kontiki is offline
Roger that. Well I don't like that the stock "bullet" housings touch the gas cap and fuel gauge cap when the bars are right at the limit - plus I don't like the look mounted to the bars anyway.
So after a bit of thinking about it and doing some research I think moving the existing stock lights to the forks is the way to go using mounting gizmos sort of like this:
http://www.amazon.com/Signal-Indicator-Relocation-Clamps-Harley-Davidson/dp/B00FEDFUZ8/ref=pd_sim_263_1?ie=UTF8&refRID=0AEQ3AB2P6JPJBE9XQ97&dpSrc=sims&dpST=_AC_UL160_SR160%2C160_ http://www.amazon.com/Signal-Indicator-Relocation-Clamps-Harley-Davidson/dp/B00FEDFUZ8/ref=pd_sim_263_1?ie=UTF8&refRID=0AEQ3AB2P6JPJBE9XQ97&dpSrc=sims&dpST=_AC_UL160_SR160%2C160_
Here's the pic:
Last edited by kontiki; 08-28-2015 at 04:48 PM. Reason: Found a link to the 49mm clamps
Old 08-28-2015, 04:52 PM
dpoll995's Avatar
dpoll995
dpoll995 is offline
http://www.amazon.com/Signal-Indicat...0_SR160%2C160_
Here's the pic:
Look on eBay, you can find those all day any size. I'm using that style of clamp for mine, but mine are black.
Quick Reply: Aftermarket Turn signals
