Clear diagnostic code on 2001 FXD
New to the forum here, been checking it out the past couple of days.
My stock 2001 FXD has been flashing the trouble code out since I bought the bike this summer. I searched the Do it yourself section (My kind of section!) and found the diagnostic codes. Ran the test and found the code to be 31 Alarm output low. I don't have a alarm on the bike! I tried to clear the code and got the bike to flash that it accepted it, but when I turn on the ignition it flashes again. Tried test again and got the same code.
I might want to mention the left turn signal would turn itself on by itself for about two days a couple of weeks after I bought it. Upon dealer suggestion, took the switch apart looking for a loose connection, found nothing and it has worked every since.
How can I clear the memory it so it does not flash anymore?[sm=dontgetit.gif]
Thanks in advance.
Thanks in advance.
chester1957
08-14-2010 02:47 PM
