vibration at highway speed
Old 08-23-2015, 11:47 AM
jeffbetrollin's Avatar
jeffbetrollin
jeffbetrollin is offline
Also this vibration occurs when I let off the throttle. Not idle or acceleration
Old 08-23-2015, 12:30 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
Yep, same thing my WG was doing before I replaced the isolator and shimmed it...
Crawl down in front of the bike with a flashlight and check the front isolator, see if the rubber is contacting the front engine mount bracket. When the isolator begins to fail it distorts and the rubber makes contact with the bracket and can give you some nasty decel shuddering. There's an HD technical service bulletin M-1324 out on the problem from May of '12, their fix was to cut the contacting rubber of the isolator away but to me it's only a temporary fix. Just like a rubber band you've stretched out it never returns to its original shape and size...
The service bulletin is posted in this thread: https://www.hdforums.com/forum/dyna-...-question.html
Old 08-23-2015, 01:04 PM
ChromeBlows's Avatar
ChromeBlows
ChromeBlows is offline
Originally Posted by Rubline
I have a 14 Fat Bob and my fingers go numb after about 10 min of riding at highway speeds. So numb in fact that I can't feel the directional buttons when I press them with my thumb. Dealer said "It's normal"
hmmm...I've got a 2014 fatbob and I'm amazed at how vibration less the bars are.I have replaced the stock risers for 6.5" pullbacks and put Kuriakin grips on it which may contribute tro its smoothness though.
Old 08-23-2015, 08:02 PM
Rubline's Avatar
Rubline
Rubline is offline
I will have to check the motor mounts. 3300 miles, you wouldn't think there would be anything wrong, but stranger things have happened
Old 08-23-2015, 08:07 PM
charger426's Avatar
charger426
charger426 is offline
Bought my FXD with 5500 miles and it had the problem. Its not a miles thing, its a Harley had a crappy design/low bid the part lol. Its a issue that is only compounded when someone does an oil change and just lest the oil run down the motor and soaks the mount in oil.
kballowe
01-22-2018 04:23 PM
Rydertp
02-07-2013 05:20 PM
nates90
05-17-2012 11:34 AM
Junior_co
04-30-2012 11:56 AM
bugzapper
01-16-2009 08:48 AM
Quick Reply: vibration at highway speed
