Metal on Metal banging In front end
Old 08-15-2015, 09:06 PM
vsick's Avatar
vsick
vsick is offline
Default Metal on Metal banging In front end
Looking for some help on an issue with my 07 fxdb. Whenever I hit I a bump I here a metal on metal knock in the front end. It hit's hard and doesn't sound good. Even at slow speeds under 10mh I here it. What are some things to look for?
Old 08-15-2015, 09:08 PM
fxdlx's Avatar
fxdlx
fxdlx is offline
Look to see if your brake pads are installed correctly, with the spring pushing down on them.
Also, do you have a fork brace?
Old 08-15-2015, 09:21 PM
vsick's Avatar
vsick
vsick is offline
No fork brace and they are brand new monitube fork inserts only 1500 miles. I'll check the brakes
Old 08-15-2015, 09:23 PM
vsick's Avatar
vsick
vsick is offline
No fork brace
Old 08-15-2015, 09:29 PM
77dream's Avatar
77dream
77dream is offline
I read in another post a while back that a bad front engine mount could move the front exhaust close to the frame. Try checking that clearance.
my $.02 good luck
Old 08-15-2015, 09:43 PM
fskitch's Avatar
fskitch
fskitch is offline
Did you check the torque on your tank bolts.
Old 08-15-2015, 09:58 PM
Chase1961's Avatar
Chase1961
Chase1961 is offline
+1 on checking the tank bolts.
Old 08-15-2015, 10:07 PM
vsick's Avatar
vsick
vsick is offline
Sounds good I'll check that. Thanks for all the help
Old 08-15-2015, 10:30 PM
WideGlideFever's Avatar
WideGlideFever
WideGlideFever is offline
Good ol' tank bolt, got me before!
Old 08-15-2015, 10:40 PM
vsick's Avatar
vsick
vsick is offline
Thanks guys it was the front tank bolt. All torqued and good to go!
Quick Reply: Metal on Metal banging In front end
