FXDX headlight relocation
Okay guys, I've been searching for the answer for a couple weeks, and I can't find it. I've tried just about every combination of words to try and find this needle in a haystack, but no dice. I've got a T-Sport Repop that came with brackets, but when I mount it up, the headlight is recessed about 2-3 inches, and its not even close to lining up with the open space for the light. I have a 2002 FXDX, so it has the top mount headlight with the eyebrow. For anyone that has done this, what are you doing to move the headlight. I looked into the Ness bracket(s) but I don't see where that fixes my issue. Anybody that can point me in the right direction, I'd really appreciative. Pics are great too! Thanks!
You need to switch to a bottom mount headlight with bottom mount bracket and drill a hole in lower triple tree for mounting it. You can buy a bottom mount bracket from JD Customs that moves headlight forward for proper alignment for about $40. If your indicator lights are on the eyebrow, the easiest way to relocate them is a bracket from Headwinds for about $50.
You can easily see both brackets in my post in the fairings sticky.
I've got a bottom mount Headwinds that sticks forward 2" past stock with a stock bracket for sale. You can see the headlight in my earlier posts in the fairing section. I swapped for a flat headlight but just as easily could have swapped the bracket instead. I'll sell you the headlight with a stock bottom mount bracket for $85 plus shipping. You'd simply need to drill the triple tree hole and buy a bolt.
Any idea if it will work with a top mount headlight? I'm going to give them a call tomorrow.
I saw this and I like...http://www.dkcustomproducts.com/Modu...HL-BRK-MOD.htm
went to put flyscreen on and one bolt i thought have snapped. But no, ts been stuck in with loads of blue lock weld. Bolt is in two pieces
sorry to jump in, But iv been looking for the bolt size for the eyebrow and headlight on a 2002 fxdx. And just my chance see your question. I would be over the moon of your have bolt size
blindrocket
09-03-2012 05:54 PM
HDRider69
10-03-2008 04:15 PM
