Bike gets hairy
Bike gets hairy
Hey guys need a bit of recommendation for something that will settle down and stabilize the bike when hitting the powerband. 2002 superglide with the built up 120 motor, when I hit the throttle and speed hits about 100mph and sometimes less the bike just gets almost into a speed wobble which is a bit scary to say the least. What would you guys with the dynas recommend? I know its because of the high torque and light weight of the bike that is causing the issue. Bike itself only has 15000 km on it so it's not like anything is worn out.
This is a good mod and may solve the problem by itself, but also check your front motor-mount isolators. They don't last very long in normal conditions. Your harsh winters, and especially any long winter storage will dry them out.
A steering stabilizer is also a good idea.
Some guys have installed a different front mount stabilizer from a British company. I can't recall the name at the moment, but it secures the front mount from any side-to-side motion (Like the Tru-Track does for the rear.)
Fresh OEM engine mounts and suspension bushings would probably solve the problem, along with setting the steering head bearings to spec.
Also, do you have apes or an after market front fender? These can set up some strange oscillating air currents which can cause a wobble.
