Squealing noise from rear
Old 04-30-2007, 12:47 AM
romac's Avatar
romac
romac is offline
Default Squealing noise from rear
When I'm out on the highway I get a squealing noise that seems to be coming from the rear of the bike. Has any one experienced this? Could it be from the read brakes?
TIA
Rob
06 Street Bob
Old 04-30-2007, 12:57 AM
baxter's Avatar
baxter
baxter is offline
Default RE: Squealing noise from rear
tell her to shut the F up if she cant ride bitch quietly....
Old 04-30-2007, 01:54 AM
mud's Avatar
mud
mud is offline
muderator
Received 9,112 Likes on 2,120 Posts
ORIGINAL: romac
TIA
Rob
06 Street Bob
Rob, if you suspect the rear brake,
lightly press the rear brake pedal.
Notice any change in the squeal??
If not, it is not the read brake.
Report back after checking this,
and we go from there.
mud
Old 05-06-2007, 12:11 AM
gigemharley's Avatar
gigemharley
gigemharley is offline
6th Gear
If you are getting a "squeaky" "chirpy" sound you may check your belt. It may be a tight and causing the chirpping sound.
good luck
Old 05-06-2007, 09:08 AM
ULTRA Gramps's Avatar
ULTRA Gramps
ULTRA Gramps is offline
I had a squeling noise that turned out to be rear wheel alinement .
Old 05-06-2007, 09:51 AM
barefoot1313's Avatar
barefoot1313
barefoot1313 is offline
mine started th same at about 500 took it in yesterday for th 1000 mile,turns out belt was too tight,still doin it a little but not near as loud may adjust it some more myself,not overly impressed wit th mechanic from yesterday. maybe i need louder pipes[sm=headbang.gif]
Old 05-06-2007, 11:09 AM
05 Wd Gld's Avatar
05 Wd Gld
05 Wd Gld is offline
ORIGINAL: baxter
evidently we had the same defective part.........fixed mine the same way.....[8D]
Old 05-06-2007, 11:30 AM
glideridemike's Avatar
glideridemike
glideridemike is offline
Mine seems to squeel/chirp whenever I have a passenger on, (no its not her, lol) and the pitch and loudness of the sound changes (usually increases) whenever I hit a bump. I tightened the belt last season a bit(brought it up to suggested adjustement as it was a bit loose) and this seemed to help, but the squeel/chirp is back. It does this with or without the belt guards on, and the belt seems to be tracking on the cog about right. The belt shows no sign of unusual wear either.
Old 05-07-2007, 12:21 PM
romac's Avatar
romac
romac is offline
Thanks for the input I will check the rear belt. I tried apply brack but the sound was still there. I will also make sure the alignment of the rear tire is good.
I will keep you posted.
Rob
Old 05-10-2007, 06:44 PM
stbobber's Avatar
stbobber
stbobber is offline
yea, I heard a squelling noise also, turns out there was a Honda behind me....
Quick Reply: Squealing noise from rear
