Help! Using heat question
Novice here...
I need to get a couple of screws loose that I can't seem to break free.
I know you have to heat them up with a torch to loosen up the locktite sometimes.
How exactly do I go about this?
How long do I heat the screw?
Do I let it cool or immediately try and break it loose while its still hot?
Thanks!
Thanks!
How about a 18 inch 1/2 drive breaker bar. Seriously.
I have never had any success with heating a tight bolt to loosen it up. It just never worked for me although I have had some success loosening tight bolts by heating up the part it is screwed into.
I have also broken a few bolts and screws in my time, enough to get pretty good at drilling, tapping, and repairing boogered holes.
Old school cheater bar !
If it is metal that a bolt is screwed into a torch is usually okay. If there is plastic anywhere around you may want to skip the torch. Some of the Loctite does require some heat. You do want to "melt" it them remove the bolt. Shouldn't take much though.
This is all for future reference of course.
