Does anyone know where I can get a map for the RUSH 1.75" mufflers and K & N air filter? IS there a map available from Dynojet that works? Thank you!
I you already have the PC you can have it dyno tuned..A custom map will run a couple hundred bucks but it will be set perfectly...If you don't have the PC and aren't planning any other mods... The stage 1 download at the dealer will put you close..Hope this helps..Later
Did you buy it from Fuelmoto? If so Jaime will give you a free map for whatever config you need.
What bike is it?
I just put on on my '06 Fatboy with a K&N. I wonder if my map will work for you.
Yeah, I already have the PC. I did not get it from Fuelmoto; it's a 07 Dyna.I found a guy here that will dyno it and map it for a little over a hundred; I didn't think of doing that at first,but it's a solid idea!Thanks for the help!
