Need A Product To Move Passenger Pegs Forward
Just like it says- I'm looking for a product that moves passenger pegs forward a few inches to clear my hard saddlebags. I think Kuryakan makes something but their website is pretty complex and it seems like you can't just buy the mounts, but then need special Kuryakan pegs too?
I am having the same problem on our freewheeler.
I will be making something based on the kit you posted.
Those are for rider cruise pegs and mount forward.
You need to drill 3 holes for the mount to connect under the floorboard.
Since the free has rider FB's I will reverse them or if need be make a new under the FB mount so I ca mount them in reverse, toward the rear instead of the front. They are very adjustable.
The bottom photo you posted is probably a 2 inch adjustable adapter. you just need to add the male clevis. I have used these they are very helpful. Them being a 360 degree swivel- adjustments- really helps. you can go up down and forward and rearward wit em.
They are a direct bolt on. The hard part is getting them adjusted to your liking. Be sure to use loc tite on the screws after you get them where you want. I had one come apart and lost the last knuckle and expensive mini floorboard.
Windseeker
06-02-2019 07:21 PM
streetglide2014
2014-2023 Touring Models
11
06-13-2014 09:17 PM
