mini rear led turn signals
Old 05-25-2015 | 08:39 PM
lesthompson1's Avatar
lesthompson1
Stage IV
Default mini rear led turn signals
Any suggestions for mini rear led turn/brake lights
Old 05-25-2015 | 08:45 PM
Tat2dale's Avatar
Tat2dale
Check out HighTecSpeed.com
The x arc lights are worth every cent you pay for them.
Brightest signal lights I have seen.
Old 05-25-2015 | 09:10 PM
Davdoodles's Avatar
Davdoodles
Ness
direct bolt-on rear signals direct bolt-on rear signals
Small, inconspicuous and really bright. Not sure if they do a rear/brake version - mine are just turns. I just wish they had one as neat and tidy for the front...
Old 05-25-2015 | 10:08 PM
RR611's Avatar
RR611
Yea those Arlen Ness ones are cool and they do come as running, brake and turn signals, a buddy of mine has them. I just picked these Alloy Art lights, the also work as running, turn and brake. Super low profile and clean
Old 05-25-2015 | 10:20 PM
slyedog's Avatar
slyedog
I love these. Got them front and rear.
The lights are about the diameter of a quarter.
Old 05-25-2015 | 11:09 PM
RR611's Avatar
RR611
Yea those HighTec lights are pretty legit. Might have to get these for front and rear. Did they wire up easily? Did you have to install a stabilizer or LED flasher?
Old 05-25-2015 | 11:16 PM
slyedog's Avatar
slyedog
I got wires custom length for front and rear. All are crimped to factory pins and housings.They are so small I drill a 5/16 hole right behind rear fender strut and put some wire sheething on for protection. Able to now use some detachable bags and still have my detach backrest. Real easy to wire if you know your wire diagram and have the basic tools. You can solder, or use butt connectors if you want. I am a little meticulous and like things to look factory. My bike is can bus so nothing extra needed. Non can bus may need a equalizer.
Old 05-25-2015 | 11:30 PM
RR611's Avatar
RR611
Thanks. How did you get the wires custom length, from HighTec? I am the same way I want it as factory as possible. My bike is can bus as well I believe. 15 Streetbob.
Old 05-25-2015 | 11:42 PM
slyedog's Avatar
slyedog
Called and asked. You can also request that in the order comments. Normally they only have 12" leads iirc. I got 36" rear and 24" front. Do not get the dual color if you do not have a separate brake light from the tail/turns. I don't have a separate brake and can't use the extra color since my turn signal wire is what also is the power for brake.
Old 04-29-2016 | 09:04 PM
mirrmu's Avatar
mirrmu
would anybody have some close up pics of the X-arc's fitted to the front of their bike?
they look like a great unit,
I purchased the JD Fabrications coffin cheaters handguards and they dont work with fxdwg stock turn signal mounts/bars, put simply if change turn signal mounts to whats on a streetbob the signals will hit tank on full lock
mini signals may be a solution
