Camchest Upgrade- Feuling Kit or SE Plus Cams
Alright so I've gone backwards with my bikes, from an 07 96", to a 2002 88".
I'm looking to upgrade the cam tensioners. Would the SE Camchest Upgrade Kit plus a set of cams be sufficient or is everything in the Feuling Kit necessary (see links).
http://www.harley-davidson.com/store...l-pump-upgrade
http://www.feulingparts.com/products...ve%20Cams/7220
Thanks for the info.
When I did my 05 Bagger TC88 I got a kit from Herko over at HTT which was all OEM HD parts to convert to hydro tensioners and the newer style oil pump. Had to run Conversion cams (Andrews N suffix) but there were plenty available. This setup used the plain bearing outer cam support but it was also much cheaper than the SE kit that still uses the old style cams. Might be worth looking into.
This was a few years ago so not sure the same parts are still readily available.
Because I had the strongest crank of any Twin Cam ('99 to '02, as you do,) all I did back at 81,000 miles (Jan '11,) is install Andrews 26 gear drive cams with upgraded Torrington inner cam bearings on my 95" motor. No upgraded cam plate and still the original oil pump. Total $$, about $800.
The bike just shot past 150,000 miles earlier this spring and I still haven't found a reason to peek back into that cam chest!
If you plan on keeping it a long time, do a complete S&S cam chest: bearings, lifters, oil pump, cam plate and gear drive cams. Bulletproof to the max. Shop wisely to get a good price. If you cam "up" now (585 cams) you will have a good bottom end for a hot 95" build later. Just got to figure out valve springs.
It gets rid of the problematic tensioners and makes your great Timken style engine solid as a rock.
You don't need a camplate or conversion cams to get where you want to go.
That being said I have done the SE new style tensioner kit in a few early TC's, and it works great. But there will always be a chain rubbing against plastic tensioners so only time will tell.
Iron lHorse
11-10-2013 07:38 AM
