Cycle shacks on a '15 LR
Just pulled the 2:1 pipes off my '15 Low Rider and installed 2:2 takeoff pipes from a '15 street Bob, with cycle shack slip ons. They sound great, are cooler as the rear pipe isn't running down my leg, and I love the sound. However the decel pop is highly amplified, due to the lack of cat and the far more open muffler of the cycle shacks. I'm bringing her into the dealer for the 1K service on Thurs, so I'm probably going to have them do the $150 stage 1 download. Hopefully it will clear that up. I also have a SE air cleaner that I'll throw on after the download.
This way I can eventually get a FP3 or a Dynojet power vision and I can save the stage 1 map so if I ever need to bring it in for a warrantee job related to the EFI I can reload the factory stage 1 map. With that they won't see a more aggressive map and they can't pull the "warrantee voided" trick.
Amazon has the FP3 for $332 delivered next day, which is very tempting. Otherwise it'll be the PV from fuelmoto - $500
I'll get photos tomorrow
What was your solution?
That's my logic. I'm basically wasting $150 for an insurance policy...
If it is going to be a long time before you get a real tuner then I'd pop for the stage 1 download just to make it a little richer and cooler. But if I was going to get a tuner two weeks to a month down the road I wouldn't waste the money. The dealership probably isn't going to ever look at you map with a flash tuner for warranty anyway
