fxdx gauges alternative help
hey guys i recently swapped my 10" tbars to 16" rolandsands king apps before i had a fairing covering the speedo/tach but now they look like mickey mouse ears and couldn't stand it so i took em off, so now i have no way of knowing if my turn signals are blinking or any of the other dash-type lights. has anyone else found a better looking way for this? thanks
Not sure exactly what bike you are referring to, but the Speedometer and Indicator Lights Relocation will help you out and will clean up the look.
To see if you will be able to use the Speedometer and Indicator Lights Relocation on your Dyna you will need to simply measure your actual speedometer (once it is out of the housing) and make sure it will fit, our Bracket for the Speedometer is 3.5” inner diameter and 2.5” tall.
With the Indicator lights bracket, you will need to look at your current indicator lights setup, and make sure they have the same light pattern as in the picture below.
Hope this helps you out
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
That's exactly what I'm looking for, I'll have to see if I can swap my fxdx speedo/tack setup with just a regular fxd speedo cluster. That bracket will fit on an 03 dyna?
Thanks for the shout out
Kelsey
Kelsey
To see if this will fit on your 03 Dyna you will need to measure your actual speedometer (once it is out of the housing) and make sure it will fit, our Bracket for the Speedometer is 3.5” inner diameter and 2.5” tall.
With the Indicator lights bracket, you will need to look at your current indicator lights setup, and make sure they have the same light pattern as in the picture.
Kelsey
