burly bars cables installed
Just finished up installing the burly 12" narrow bottom apes and their 12" cable kit. This was my first time taking the bike apart to this level and it really wasn't that bad. I had one little hiccup with the clutch cable/clutch cover. Some how the threads got boogered up and I had to retap the cover to get the cable to screw in. I also got a c&c fastback seat a couple of weeks ago which I love. I haven't ridden with the bars yet, but I did go down the street and it feels way different. I guess I'm just gonna have to get used to it. I had drag bars on the bike before and had plenty of wire in the neck. The throttle seems really sensitive now, but it could just be in my head. The burly cables seem to be of good quality. I went back and forth on weather or not to get the 12"s or the 14's and I'm glad I went with the 12's. Here are a couple of pics...Thinking a set of white walls would complete the look?
Edit: Forgot to add, the risers are 1.5" la choppers brand with the smooth top...while this looks better than having the screws exposed, it makes it nearly impossible to tighten down the bars cause the wrench hits the top of the tripple, so you have to remove the bars and risers as one and tighten them down that way. Total PITA and I wish I would have thought that thru before ordering those.
The best way to do it is to mount the bars, and measure what length you need and round up to the next size. I went with the Black Pearl finish from Magnum Shielding. Unless your bike has the same length stock cables as mine, the stock plus measurement I used won't work. I had 12" apes for the last 7 years and used all stock cables and wiring, I did have to reroute the throttle cables so they weren't running through the trees. With 14" bars on mine, +2 or +4 cables are plenty long enough. Any longer and I would've been swimming in extra cable length which looks bad to me.
2lane69
04-04-2012 04:53 PM
